What actually resets the "Since refuel" MFD?
Viz
Vernon, NJ
2001 & 2002 MKIV, 2015 MKVII
Is there a switch that is activated when you open the fuel door that causes the reset of the "Since refuel" MFD ? Or, is there a float switch in the tank, or, what ?
I would hope that it's not triggered by opening the fuel door, since that doesn't have to result in any fuel being put it, say for example someone opens it by mistake.
Viz
nayr
Colorado
2014 Audi Q7
probably software routine, store fuel level at shutdown, compare at startup.. if changed dramatically = refill.. or mebe it just resets it when level rises more than a trigger point.
JettaRon91vw
Fort Stewart GA
2015 GSW SE DSG
I can confirm that simply opening the fuel door does NOT reset the MFD. It must go off of the difference between the shutdown level and startup level.
TurnOne
Cincinnati, OH
2015 Golf SEL TDI 6MT
I have left mine running during fillups and it resets usually before I get out of the station lot or sometimes just after I'm on the road. Or at least that's my recollection. I usually keep my radio display on the screen that shows mpg since refuel.
EECSentric
Arlington, MA
2015 GSW TDI SEL DSG LP
I generally record the stats for every tank just after I fill (MPG, miles, odo, etc.). It seems to me that the "Since Refuel" screen doesn't change when I start the car after a refuel but it does resets as soon as I move the car.
giuseppe_b
Albuquerque, NewMexico
2015 Golf SportWagen SE 6MT
^ My observations too. Once the computer detects that the miles to empty has gone up from the last stored number, it resets once the car moves. I'm glad there's that delay, just in case I miss something when gathering my stats and entering into fuel log app once I start the car after refuelling but before driving off.
Colville
North Carolina
2015 Golf Sportwagen TDI SEL "The Modern Squareback"
From my experience, once you put the car in gear to drive, that resets it.
