Nash_TDI
Veteran Member -TDIClub Enthusiast
Got a customer's car in for a manual swap and having N75 issues. Not sure how the car ran beforehand, but I'm fairly sure it is unrelated. The car will not run the N75 output test. It goes from 5% duty cycle to 55% for a 1/2 second then back to 5%. It doesn't evey try to run the output test correctly.
All the vacuum lines were replaced and tried a separate n75 that was known good. Appears to me to be electrical related and not vacuum or n75. Thought the we might of messed up the manual swap wiring, but it was all fine.
Anybody have the pin outs of the n75 control for the B5 and wire routing? What should the signal look like.
