a_randy_sewer
Selling both of my vehicles to consolidate into something way less fuel efficient. Got my sights on a 1997 Suburban 2500HD with the 454 V8.
The vehicles and I are located in Frederick, MD.
I've completed most of the work myself outside of having bearings pressed in my the local machine shop. I have all of my receipts from germanautoparts.com available to the next buyer.
I will update the albums with new photos once the weather clears up, until then please enjoy these photos I've taken over the past 1.5 years.
I will do my absolute best to describe the vehicles with the most detail I can recall and provide proof of work through receipts.
2005 Passat TDi 6 Speed Wagon Black 197k miles ($9,000 without the Winter Wheel set $9.5 with)
Yep, same Passat from this Jalopnik article.
ALBUM (going to update with detailed pictures of each wheel, panel, scratch so the buyer gets the real deal)
QUICK: 1.5 Malone Tune, 6 speed, GTI wheels + Audi winter set
I change the fuel filters every 20k and drain every 10. Always used diesel purge. The passat is 5k miles away from its next oil change, I have a bottle of FUCHS Titan GT1 and a filter for the buyer if I don't complete it by then.
I'm sure I have forgotten a lot, going to go through my receipts and see what I have left to cover.
- Purchased with 163,000 miles in August 2015 in Missoula, MT. I flew out and drove it back in 44 hours including stops. Performed amazing although the water temp never rose to operational temperature.
- TB was replaced before purchase at 160k miles
- BHW has had the BSD performed
- 166K replaced the thermostat and temperature sensor
- 170K miles installed OEM monster mats
- 180K miles I noticed 1/4" of water in the floor behind the driver seat, I've cleaned the sunroof drains and replaced all of the hoses with better, wider, and firmer hose that will not clog again. Zero issues since.
- 05/16 replaced the rear pads and rotors, will come with
- I've replaced the passenger axle at 190K miles, the driver will need it soon. Trying to find the time to complete before sale.
- 197K I replaced the fan clutch bearing. Still need to put the front end into service mode so I can replace the clutch fan/pulley and install the BFI stub mount.
