YOU’RE WORDS
and I quote.
( Had a road rage incident the other morning )
So my question to you sir, why are you calling the police ? Did you report the part you played as well ?
Takes two to tangle, just saying.
Hi
I was driving back home after doing a courier run on 29 south around 3 am or so ... speed limit was I think 55 or 60 on that stretch of road... ( 4 lane road ... 2 lanes in either direction).
I was doing the speed limit ... no other cars on the road for the most part.
I came around a bend and a pick up truck was doing maybe 45 mph or so ... maybe a slow driver or just pulled back on road but I did not know so I went around him... turn signals and all and plenty of distance before and after getting back into the right lane.
The truck was several hundred feet back but rapidly approached me .... getting real close then backing off ... by close I mean probably within 5 feet or so..
I was doing the speed limit and road was empty.
This happened several times over several miles...
After a few miles of this I did 5 mph over ...
Same thing happened now driver was nascar drafting me ...really close ... like getting ready to park close.
I slowed down to speed limit.
After a mile or so he went around me... but he cut over early causing me to brake and slow to 50.
I figure give him space to go ... but he stayed at 50.
I went around at some point a few miles down the road and then he started drafting me again...
Having had enough of that I called 911 because drafting was crazy dangerous...
The dispatcher had me call out my location and signs along the route for police to intercept....
Eventually at an exit the truck veered right and got off while I continued straight...
Sadly on the other side of the overpass there sat the police in the right lane by a sign .... too bad the truck had just pulled off or they could have seen the drafting...
I described the pick up as best I could ... regrettably I did not think to get a plate number ...
I had a dash cam set up originally for when I did uber(filming inside and out in case of problem riders).
The camera stopped working for some reason (maybe summer heat on the camera inside s hot car?).
Anyways. after that incident I got another dash cam ...
As far as I know , other than me being there on the road, I did not do anythin against the other driver .... I used turn signals , always plenty of clearance when I passed and pulled back in etc... even did speed limit or a little above but always steady on an otherwise deserted road....
As far as I could tell there was really no reason for what happened to have happened.
In retrospect, if something similar happens in the future , I will try to get plate numbers soon and call police sooner ...of course the dash cam will be on too...
