It's not symptomatic of a bad j329 since it never dies when running. It sometimes make a rattling electrical sound when attempting to start, not like a low battery click sound. It will normally start even with the rattle. It just might take a few tries. Sometimes it be like the battery is dead, no power at all. If I open the hood and wiggle at all the thick battery cables it will normally start ok. This started getting worse after I relocated the battery to the trunk over a year ago. All connections are clean, no loose battery cable. I've tightened and cleaned all the connection points. It will start ok 90% of the time. I'm using 2/0 welding cables for the positive. Ordered another cable to run ground all the way to the starter. I highly doubt that is the issue but might as well. It's getting annoying as hell.
