'12TDITweaker
Hello all,
I could use a little assistance. The 12V cigarette plug in not getting power. Has anyone else run across this issue? I've heard its common because a penny fits perfectly.
The fuse is good. F30 i believe its a 20A fuse that is not blown. I do have a fantastically cheap harbor freight (free gift) multi-meter. I have disassemble the center console by using a micro flat head screwdriver to gently pry up the gear shifter cover followed by removing the two (2) small torx screw to remove the coin tray as well as the 3.5mm audio input.
How can it use the multimeter to test if there is 12v power to the wiring connector? (Do I need a seperate ground?)
How can I test the plug itself to see if it is functional?
Related but not. If there's not fix but to redo the wiring, Does anyone know of a firewall penetration i can easily access to run wiring directly from my battery to a power inverter? (I prefer this option as I would be able to charge my laptop while on the road)
Thanks in advance.
Thanks in advance.
