BakoTDI
Trying to diagnose why my car won’t start. Battery is good. Starter is new. Checked power to clutch sensor and I did get 12v there. Checked for voltage on the wire going to the starter solenoid and got 12.3v. So I then checked other posts and got directed towards relay 109. Went under dash and found this..
So, how is the relay supposed to work without the fourth terminal!?!? Am I missing a terminal here? Looked behind the relay connector and I don’t see the fourth wire anywhere. Should there be a fourth wire? The relay itself has 4 prongs, but the diagram on it only shows 3 being used. What am I not seeing here!?!?
