Q Quick2004 New member Joined Jun 19, 2019 Location Wales TDI Golf mk5 1.9tdi Jun 20, 2019 #1 Recently bought golf mk5 1.9tdi 2007 major issues every time take sharp left back end wobble around corners
M mextdi Veteran Member Joined Dec 16, 2013 Location Saint Paul, Minnesota TDI 2006 Jetta TDI 1.9, 2012 Passat TDI SE DSG, Previous 2014 Beetle TDi, 2012 Golf TDi DSG Jun 20, 2019 #2 I would look at your rear sway bar and links, if those are loose you would definitely get some wobble.
Q Quick2004 New member Joined Jun 19, 2019 Location Wales TDI Golf mk5 1.9tdi Jun 21, 2019 #3 mextdi said: I would look at your rear sway bar and links, if those are loose you would definitely get some wobble. Click to expand... I’ll check that out after work m8 thanks for reply
