RogueB4
'96 B4V Passat Wagon - Saranac Lake, NY - $3,900 OBO
(last updated: 11/7/20) YES, THE VEHICLE RUNS
Timing Belt replacement: NOT since I've had ownership (I've put roughly 16k miles on the vehicle).
Cosmetics:
Some minor broken pieces in the plastic trim, discoloration, and sagging headliner, and some scratches, rust on the rear quarter panel (not original since I took ownership), and small dent near taillight on driver-side (visible in the pics). Tape deck no longer works, radio does work.
The body/chassis has 277K miles and engine has 123K miles (replaced in 2005 with a '97 (1Z) engine that had 5K original miles according to records).
Repairs/upgrades:
Suspension (2017)- rear & front HD coils- new Bilstein rear shocks and struts
- all new strut stops, shock stop, strut mount, strut boots[/FONT]
- essentially rebuilt with all new OEM bushings for sway bar and links. New ball joints, etc. Reman CV drive axle (still have old/original if you want to rebuild) - repair done by shop in Ohio while I was traveling (have records).[/FONT]
- new brake pads (Mintex Red Box) and bearing repacked.
- Frost Heater installed (works great in -30 F temps of MT)
- replaced power steering pump (new from IDparts)/bracket/belts, oil cooler gasket.
Known Project List:
Timing belt kit (this fall/winter), replace all IP seals (slight drip on QA lower seal), repair/fix foam in heating blend door, replace shift knob boot.
Most of you know I could go on with this portion of the post but just know this vehicle is not for those who cannot and do not enjoy mechanical work - it can become cost prohibitive very quickly if not willing to do most work yourself. This is not a maintenance free vehicle. That being said, it is a unique vehicle to be own and one that you can learn a lot from if you have the time.
I will include all parts new and old, unopened manufacturer specified fluids (motor oil, brake fluid, coolant) which I’ve used exclusively, an extra set of 4 wheels (running Blizzaks on factory rims currently), and all purchase and maintenance records.
If you have serious inquiries, please message me directly so we can set up a phone call.
There are photos HERE for you to view.
Cosmetics:
Repairs/upgrades:
Known Project List:
