DayMan8404
My clock is 7 minutes fast, so not the worst thing in the world, but the button that changes and rests it isn’t working. Wondering if maybe it’s fuse issue or if I need to pull the dash apart to figure it out.
Push button with clock symbol, highlight what I want to change (minutes), push 0.0/SET button, nothing happens.Hold on a sec, can you go through the steps you're taking to try and reset it first?
I can switch between everything. It won’t change the time or reset the maintenance. It does nothing.OK, so the right button on instrument cluster isn't working to change minutes.
Have you tried changing the hour? What about being able to switch between odo and trip meter?
