2013 Passat TDI stalls in Drive and Reverse
HI
I have a similar problem that surfaced last week. I had the HPFP crap out on me (you can read my other thread and frustration with a crook dealer in Toronto); who blamed that I added gas to my diesel after adding gas to the tank. It should have been covered by VW under extended emissions warranty.
Anyways fast forward, I had another dealer change the HPFP (as I was afraid of getting the timing incorrect if I did it myself). The car did not start after the HPFP was replaced, so I brought it home and cleaned the RAIL and replaced the injectors with used that I bought from Ebay. I also changed the fuel filter and flushed the lines and cleaned the tank. Filled it with fresh Diesel and it ran fine for about 10,000kms until this problem surfaced.
The problem is that it stalls when I put it into drive and let go the brake and press the Gas pedal. I understand how DSG works and if I do press on the gas too quickly it could stall. That is not the case here. I cannot seems to make a left turns any more and it stall on when taking off traffic light. It does same when in reverse. The only thing that helps it in not stalling it when I let go really slowly and even then if you press on gas there is no throttle response for at least 2 to 3 seconds. I tried backing in a parking spot today and it stalled 3 times.
I already ran a clutch adaptation procedure and it did not help.
It lacks power when driving but when pushed would got 4500 RPM on up hills. It doesn't seems to have the torque it use to have. There are no codes except for one for MAF and Intake Temp Sensor. I have cleaned the MAP (03G 906 051E) but it still the same.
I also unplugged the MAF but nothing changes. I checked the Air filter and it looks reasonably clean. Also removed the Air Filter and did short test drive, no change.
Also after doing a lot of research for this issue with stalling some have reported that there is a Firmware update that a dealer can do to fix stalling issues. I talked to the dealer and they said they have not heard anything like that.
Address 01: Engine Labels: 03L-906-022-CFC.clb
Control Module Part Number: 03L 997 009 J HW: 03L 907 309 S
Component and/or Version: R4 2.0l TDI H21 9982
Software Coding: 001D0012842400000000
Work Shop Code: WSC 93007 999 00000
ASAM Dataset: EV_ECM20TDI01103L997009J 004005 (VW41)
ROD: EV_ECM20TDI01103L997009J.rod
VCID: 3B7F6A2FB265A792C0-806E
3 Faults Found:
12642 - Charge Air Cooler
P026A 00 [237] - Efficiency Below Threshold
MIL ON - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 1
Mileage: 279968 km
Date: 2077.14.04
Time: 18:50:10
Engine speed: 1691.50 /min
Normed load value: 77.3 %
Vehicle speed: 74 km/h
Coolant temperature: 100 °C
Intake air temperature: 48 °C
Ambient air pressure: 980 mbar
Voltage terminal 30: 14.100 V
Unlearning counter according OBD: 40
Air mass at air mass meter 1: 132.9 kg/h
Temp sensor for low-pressure EGR after cooler: raw value: 102.9 °C
Outside air temperature: 19.0 °C
Intake air temperature before throttle valve: calculated: 31.7 K
Sensor for temp after charge air cooler: raw value: 48.0 °C
Coolant pump for charge-air cooling: spec. value: 95.00 %
8842 - Torque Difference Cylinder 1
P1004 00 [096] - Limit Value Exceeded
Intermittent - Not Confirmed - Tested Since Memory Clear
5552 - Intake Air Temp. Sensor (G42)
P0111 00 [101] - Implausible Signal
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 280104 km
Date: 2077.14.07
Time: 13:26:17
Engine speed: 1094.50 /min
Normed load value: 100.0 %
Vehicle speed: 0 km/h
Coolant temperature: 24 °C
Intake air temperature: 73 °C
Ambient air pressure: 990 mbar
Voltage terminal 30: 11.860 V
Coolant temperature at radiator outlet: actual value: 24.8 °C
Fuel temperature: 31.1 °C
Outside air temperature: 27.5 °C
Control Module temperature: 30.4 °C
Shut-off timer: last engine shut-off time: 32808 s
Sensor for temp after charge air cooler: raw value: 73.0 °C
Readiness: 1 1 0 0 0
Thursday,04,July,2019,09:48:37:00007
VCDS Version: Release 18.9.0 Running on Windows 10 x64
www.Ross-Tech.com
2 Faults Found:
P026A 00 [175] - Efficiency Below Threshold
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 280167 km
Date: 2077.14.14
Time: 14:35:33
Engine speed: 1238.50 /min
Normed load value: 99.6 %
Vehicle speed: 65 km/h
Coolant temperature: 99 °C
Intake air temperature: 113 °C
Voltage terminal 30: 14.120 V
Air mass at air mass meter 1: 87.3 kg/h
Temp sensor for low-pressure EGR after cooler: raw value: 98.5 °C
Outside air temperature: 25.0 °C
Intake air temperature before throttle valve: calculated: 35.2 K
Sensor for temp after charge air cooler: raw value: 113.3 °C
4795 - Mass Air Flow Sensor (G70)
P0101 00 [039] - Implausible Signal
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 280195 km
Date: 2077.14.23
Time: 09:10:01
Engine speed: 1593.00 /min
Normed load value: 0.0 %
Vehicle speed: 53 km/h
Intake air temperature: 114 °C
Voltage terminal 30: 14.060 V
Air mass: actual value (mg/stroke): 590.5 mg/stroke
Standardized airflow ratio: filtered: 0.8303
EGR Solen.val.: actual value: 99.60 %
Throttle valve adapter: actual value: 100.06 %
Charge air pressure specified value: 1013 hPa
Charge air pressure: actual value: 1198 hPa
Mean injection quantity: 0.00 mg/stroke
Readiness: N/A
