ARCJr
I've searched the forum but the other threads I've found have slightly different issues.
As in the title, whenever I turn the ignition off, the Clock and Trip/odo displays go blank and all of the dials freeze in whatever position they were in when the ignition was on. Whenever the ignition is turned back on, the clock and tripmeter have reset, and the dials flutter to a zero position.
I found that fuse 15 had blown, and it instantly blows when it is replaced. I removed the instrument cluster and did not see any damaged or frayed wires.
I have no issues starting or running the car. The radio (aftermarket) retains all of the presets, bluetooth code, etc. I'm not having issues with the internal or external lights (that I've noticed).
So, I guess I'm looking for the next step to diagnose the issue. Thanks in advance for your help!
