I've been reading this post. At first, you say that "splash mixing" isn't good enough. Now, you're saying that the D2 will mix in the fuel tank because of sloshing around, etc.
I'm a little confused as to what you are saying is best, pre-mix prior to pouring into tank or "splash mixing" or maybe something else.
Also, does splash mixing, or any other type of mixing help a TDI engine with lubricity or does this have other good results (favorable factors)?
I haven't heard much discussion of the value or benefits of mixing or using bio-fuel by any mixing methods (e.g., fill up once in a while, pre-mix or use small quantities per tank of fuel). What would the benefits be and can you put a value on them? Also, what are the bad points, i.e., detriments?
Apparently, based on this conversation....other factors apply, like humidity levels of the location. It appears that water, or condensation, is a key point of concern.
So, my "take-away" based on this thread is that there "might" be a benefit to mixing bio-diesel with regular diesel which could be, lubricity. However, this is assumed. I"m not sure if it is so. But, on the other hand, if water accumulation in the fuel system is a concern when you mix, that's not a good thing. In fact, water may blow the whole theory of mixing being a benefit out of the water. So, does water in the fuel actually "outweigh" any alleged lubricity benefit? Is this what you are saying?
Never the less, based on my reading of this "scholarly" conversation, there are no posts on #1, if mixing is really a benefit and what are the benefits, #2, whether or not mixing would work for my TDI in my region and why.
I guess you guys are simply talking about "methods" of mixing, which is best and why.
My CTSs are whether or not this is a good thing to do or not. If it isn't, there would be no need to speculate on the mixing methods. I've read threads on bio-diesel, but I can't seem to get a good concensus of what is good for your TDI and why. I a few blurbs of opinion, but no solid data or verifyable info.
Suggestion: Wouldn't it be nice to see a spread sheet on the benfits and detriments (+ and -) of using a mix of bio-diesel and fuel?
Thereby you can measure the data as to the value of mixing boi-diesel with fuel in different regions or by using different methods....or not. I'd like this!!!!!
If the chart was going to be more complex, or have better data, you could enter other variables like types of engines...if this matters....like the size, 1.9L, or whatever (if this makes a difference).
This seems to be the best method to me of calculating a bottom line of variables, rather than speculating.
But, on the other hand, discussions are interesting and fun. I guess that's the point. Spread sheets are time consuming, boaring for sime, less temoral, more cerebral....
