bawward
- Joined
- Apr 14, 2015
- Location
- Steamboat Springs, CO
- TDI
- 02 Silve Jetta Wagon - 5spd. w/ SB St.2, PP520's | 02 Green Jetta Wagon - 5spd. OEM | RIP 2003 Black Jetta Wagon - 5spd.
Hello all,
I've got an 02 Jetta Wagon, 5spd. 180k.
I've had it three months, very happy. A little bit too much smoke / rpm "catch" at cold startup, but everything else is tip-top. I've done the filters and fluids already.
Q1: - I am going to get nozzles (520's probably?) as well as Malone 1.5 tune(probably?) - I will have the nozzles installed professionally while the timing belt is being done. - Should I have the nozzles installed, the tune put on the ECU, THEN return to the shop to have them calibrate? Or have the nozzles installed, the engine calibrated by the repair shop, THEN have the Malone 1.5 applied to the ECU?
Q2: - I have a set of gauges (EGT, Boost) that will be installed before the performance upgrades. I've heard that Malone 1.5 uses dynamic EGR, however I was considering deleting and removing the cooler as this was also an easy time to install each gauge (on the block-off plate for the EGT) - Should I leave the EGR in place if I'm going to get the tune? Or, should I remove, plate off and install my probe in that block-off plate?
Thanks guys - I'm sure more questions will come to mind later. Thanks for your time in advance.
