When I asked him via PM DanG144 recommended the hose linked below in 5/16" and that is what I used.
http://www.dudadiesel.com/viton.php?affiliate_pro_tracking_id=17:18
Wow this is definitely cause for concernALL of the hoses (at least 3 different types and sources) have shown issues.
If the hose was tough enough to last, it would kink when it heated in the tank, even if it was unkinked on installation.
The Polyeurethane hose was only good for a few years of service. It will not last - it gets brittle and weak.
The viton would eventually tear.
The viton and rubber with fabric sleeve in between would kink - often after it got hot in the tank.
If you could get the corrugated hard hoses that were originally used - of the right length, it may work and last.
The idea is elegant, the execution is problematic.
I regret that I ever modified any of my (and especially my friends) pumps.
Well, it's not the end of the world.Wow this is definitely cause for concern
hey Dan, how about using some rescued tank to engine bay plastic line from an mkiv junker ?... that line appears to be in and out same material so it may tolerate long term fuel submersion ... it's also fairly easy to work over fittings with a little heat assistance ... maybe try it out at the next gtg ?If anyone can do it, you can, Jimmy.
The fittings built into the pump, the canister lid and the jet pump are all barbed fittings - 8mm if memory serves.
Changing them all over, in the space available, as kiwibru mentions, would be very difficult.
There should be a previously modified pump (two in fact) at the GTG in January at my place. I would welcome input from anyone.
The only hose I can find that looks suitable is only available in 1 foot lengths or longer from McMaster Carr. It is a corrugated teflon hose that must have shaped ends, so it does not appear to be suitable in those lengths. http://www.mcmaster.com/#standard-plastic-and-rubber-tubing/=zi70x1 (it also comes in clear).
TheTDWagonGuy that sells the electric motor pumps for replacement has some source for hoses, given what comes in his kit. I have not approached him about this, but it seems the only present lead I have.
