AC Vac leak?
Ron22
Forest Lake, MN
2002 Jetta
Maybe a dumb question but is the AC controlled by vacuum anywhere?
My AC stopped blowing cold today, I also noticed the turbo is not building boost correctly. Last time turbo did this it was a vacuum leak. Just hoping I have 1 problem not two.
Sent from my iPad using Tapatalk
wonneber
Monroe, NY, USA
I'm thinking electrical.
Something common to both.
My quick look didn't find any common fuses.
Grounds are in different locations under the hood also.
Long shot but if the body ground under the battery tray is bad anything grounding to other body locations would be bad.
