I never clicked on any of the links in this Thread. But, I can tell you one thing for sure, if a "chunk" of that Crud breaks off and goes into a cylinder(s) you will most likely be pulling the head!
You don't need a kit to remove the Intake and clean it! The Intake Gasket can be reused numerous times without any worries of it leaking!
For those who have removed an Intake, you know there's a lot of scraping, gouging, brushing, looking, more of the same, etc., to clean it out.
There are several Theads on Intake cleaning! For those not restricted due to local laws/ordinances, the Burn out method works well. Of course, that method also requires the use of other means to finish up! No, you will not generate enough heat to warp/melt the Intake!
Unless time is an issue, after burning out, any strong cleanser such as Power Cleaner, Awesome, etc., can be used to finish up. I have a cap-off plate that I bolt on the EGR end of the Intake. Then I pour in a mix of my favorite cleaner......let it sit for about 4 days. That soak typically loosens 99% of what's been left after the burn!
