MAXRPM
02 golf Alh, timing dead on, fuel dead on, wont fire up, VCDS says QA reached lower limits, opened the pump from the top then cycled the ignition key, QA needle on top of the pump does not move at all,,,, im thinking this may be electrical,, how could I do more check about N146 QA I VCDS says sensor malfunction, maybe a bad ground any advice,,, I haven't checked meas block 19 yet,, but im welcomed to any advice rom you guys as always thxs ahead.
