JetFixxxer
and then died. It will not start up now. Check to see if filter was filled it was and then I removed the filter and used the water drain to drain a little out. Top off filter with diesel. Reinstalled filter and still not starting. Once in a while I get a puff of white smoke out of the exhaust.
It's on a 2002 Jetta. Any other suggestions. I've tried to turn over for 20 seconds. Wait a minute and repeat three more time and then wait 10 minutes and repeat. I have been doing this for the past couple of hours.
