Nevada_TDI
The immobilizer symbol doesn't always turn on even when the immobilizer is the issue. The other possibility is the IQ has moved just far enough to start but not keep running.
Yes, but it involves sending the ECU away to a tuner... can't be done thru the OBD2 port.Any way to disable mobilizer?
I had a situation... I mean, I HEARD OF a situation where some numbskull swapped the PCV heater wire with the ASV wire and it would do this. I know you said that you watched it, but a quick and free test is to unplug the ASV and try to start. Probably not it, but it takes just a few seconds to be sure.ASV is wide open, can observe whilst helper cranks.
Have tried both fobs and the non fob key as well.
