pgringo
03 jetta ALH 5speed.
manual climate controls
my compressor clutch engages. low side and high side get up to and sit at around 60psi while trying to charge system. would i be likely correct in diagnosis that the manifold in the compressor is probably bad? or that valve in the compressor?
i'm thinking about just grabbing one of those florida rebuilds with expansion block and drier and o-rings off ebay and going for it.
i have the harborfreight gauges and vac pump, but this is my first time at serious a/c diagnosis & repair. i do all my own wrenching.
