Old May 4th, 2018, 19:31   #1
x12gt
Fuel Economy: Pretty Rough
Default EGR/tuning question
In a few days I'm going to go stage 1 through Malone, and my EGR cooler hiss is growing louder and louder everyday, would the Dynamic EGR option which turns down the EGR after warmup fix this or do I need to block it off and completely delete it?
x12gt is offline   Reply With Quote
Old May 4th, 2018, 21:13   #2
narongc73
Get blocking plates and disable egr with the tune. Dynamic egr is for a known good egr.
narongc73 is offline   Reply With Quote
Old May 8th, 2018, 03:39   #3
Rx7145
TDI(s): 2006 Jetta
I agree
Rx7145 is offline   Reply With Quote
Old May 8th, 2018, 05:10   #4
oilhammer
oilhammer's Avatar
Fuel Economy: fantastic
Yeah, if your EGR cooler is leaking at the changeover flap shaft, like they all end up doing on the BRMs, you'll still need a new cooler to accomplish what you stated.
If you are handy, you can remove the cooler, cut the shaft and flapper out of it completely, weld the end holes shut, reinstall it, and continue with your plan of dynamic tune. However, when you do that, you eliminate the full heat exchange ability of the cooler since that flap is no longer present and only half of the actual EGR flow will pass through it (the rest will just bypass). So it sort of diminishes the reason for having that sort of tune anyway.
oilhammer
www.cardocautomotive.com
Old May 9th, 2018, 16:14   #5
x12gt
I ordered the buzzken delete kit, thanks for the help as always.
Question regarding EGR cooler after DPF/EGR delete wild03 TDI Power Enhancements 5 February 8th, 2016 10:47
Help me decide on tuning options (egr, etc.) SFHGolfTDI TDI Power Enhancements 37 May 25th, 2015 22:30
Egr tuning for off-road use 03_01_TDI VW MKVI-A6 Golf family including Jetta SportWagen (~ 2010-2014) 1 April 7th, 2013 07:05
EGR and ASV removal ok without tuning? sauron18 TDI 101 3 January 17th, 2013 12:26
PD tuning question, what is the difference between RC, JSP, and KermaTDI tuning? sweatmachine TDI Power Enhancements 2 September 21st, 2007 11:47
Page generated in 0.16073 seconds with 11 queries
[Output: 66.86 Kb. compressed to 59.15 Kb. by saving 7.71 Kb. (11.53%)]
