Precisiontuning
Registered Vendor , w/Business number
- Joined
- Aug 18, 2005
- TDI
- n/a
Liquimoly Cera Tec is now available at PTM.
$22.99 plus tax per bottle.
DESCRIPTION:
Micro ceramic solid lubricant suspension based on hexagonal boron nitride (BN) in
mineral oil. The laminar graphite-similar structure reduces friction and wear and
prevents direct metal-to-metal contact. The < 0.5 μm particle size guarantees
optimal filter flow properties and protects against depositing of solid lubricant
particles.
PROPERTIES:
- Mixable with all commercially available motor oils
- Stable even under high thermal and dynamic permanent loads
- No deposits and absolutely compatible with all commonly used filter systems
- Resists extremely high and low temperatures
- Reduces fuel consumption
- Increases engine service life
- Increases smooth operation
- Stable under extreme pressures
- Chemically inert
- Higher performance gain due to reduced friction
- Does not increase the phosphorous and sulfur content of the motor oil
- Tested with catalytic converters and diesel particle filter
TECHNICAL DATA Base :
BN micro ceramic
Color: : Yellowish white
Ceramic particle size : Majority < 0.5 μm
Temperature stability of the
ceramic particles : To +1,200 °C
Density at +20 °C : 0-89 - 0.90 g/cm³ DIN 51757
Viscosity at +20 °C : ~300 mPa*s DIN 51398
Flash point : 200 °C DIN ISO 2592
Pour point : -20 °C DIN ISO 3016
DESCRIPTION:
particles.
PROPERTIES:
- Chemically inert
BN micro ceramic
