I've got a no start condition that I'm a little confused on. I've been reading all of the great info available, but nothing seems to fit.
It's a 2002 TDI Golf, ~105,000miles. Intake cleaned and timing belt replaced about 20,000 miles ago.
Checked the anti shudder valve, it's moving freely.
On initial startup the car starts, runs and then dies. After repeated attempts the car runs for shorter and shorter periods of time until it won't start at all, but does turn over.
Each time I take a brake from trying to start it the above scenario repeats itself.
Here are my codes:
5 Faults Found:
16629 - Solenoid Valve (A) for Boost Pressure Control (N75): Short to Ground
P0245 - 35-10 - - - Intermittent
19459 - Relay for Low-Output Preheating of Coolant (J359): Short to Plus
P3003 - 35-10 - - - Intermittent
17946 - Fuel Shutoff Solenoid (N109): Open or Short to Ground
P1538 - 35-10 - - - Intermittent
16502 - Engine Coolant Temp. Sensor (G62): Signal too High
P0118 - 35-10 - - - Intermittent
17056 - Cylinder 2 Glow Plug Circuit (Q11): Electrical Fault
P0672 - 35-10 - - - Intermittent
Readiness: 1 3 0 0 0
Any help would be greatly apreciated.
Here are my codes:
5 Faults Found:
