rwa227
I am trying to fix a "limp mode" problem on 2004 Jetta.
VNT actuator doesn't hold vacuum. I assume it is shot.
This VNT actuator is steel on the upper half and plastic on the lower half with a 3 pin conector (position sensor?) Lenco Electronics 180183.
Where can I purchase a VNT actuator with built in position sensor?
The ones I see on line are just simple vacuum diaphrams with no electrical connection.
After pumping like crazy with a hand vacuum pump, the VNT stayed in an intermediate position for a while, but now it is back to limping a lot!
In the interim, I'm trying easing up on the adjustment to not apply so much spring pressure. I don't mind not having boost at lower power levels, but the "limp mode" under demanding situations is very unpleasant.
Thanks for any help you could provide!
Grace to you and Peace
Roy Alexander
Roy Alexander
