Old November 18th, 2018, 16:36   #1
McGuillicuddy
Fuel Economy: 5.6 L/100km
Default Oil consumption: 1qt per 4500 miles. Concern or no?
No other symptoms. No major leaks. No significant smoke of any color. Car is a bit stinky at idle but I don't think it's out of the ordinary for an ALH (is it?).
Car is driven 80-90% highway, although I do drive it a pretty spiritedly most of the time.
'The Battle Wagon'
McGuillicuddy is offline   Reply With Quote
Old November 18th, 2018, 17:27   #2
ToxicDoc
TDI(s): 2001 Jetta
1 qt? I'd be happy to lose that little.
ToxicDoc is offline   Reply With Quote
Old November 18th, 2018, 18:36   #3
Prairieview
No, it is a major biohazard.
Please have it in front of the crusher tomorrow morning by 08:00.
There will be a warrant out for you if you do not meet the deadline.
Seriously, why do people ask questions like this?
Prairieview is offline   Reply With Quote
Old November 18th, 2018, 19:45   #4
STDOUBT
STDOUBT's Avatar
Because some of these cars "burn no oil" and remain at fill spec between 10k mile oil changes? Because the idea that burning oil could indicate a brewing engine failure is not unreasonable?
2003 Jetta TDI 1.9L 5-speed
Malone Dynamic EGR ~ cooler delete ~ Euro pipe ~ ventectomy
Search Tip: search this site best by using Bing: tdiclub topic
STDOUBT is online now   Reply With Quote
Old November 18th, 2018, 20:32   #5
[486]
TDI(s): 02 golf ALH
most major manufacturers' spec is 1qt/500 miles before they'll do anything about it
[486] is offline   Reply With Quote
Old November 18th, 2018, 20:35   #6
ToxicDoc
TDI(s): 2001 Jetta
A little harsh, don't you think? It was a simple question.
Old November 19th, 2018, 04:14   #7
Tdijarhead
Check the back of your engine you may not be burning so much as leaking it. The valve covers on the alh are notorious for leakage, especially from the rear coating the back of the engine.
Tdijarhead is offline   Reply With Quote
Old November 19th, 2018, 04:34   #8
mk3
mk3's Avatar
Fuel Economy: 46.4 lifetime
mine has 300k+ miles on it with original, untouched turbo. in the last couple of years I've noticed the oil goes low between oil changes. I probably should watch a little more often now. This is a big contrast with gasser VWs that I had in the past which always needed topping.
I think it is a moderate concern. I'd worry about the seals in the turbo so perhaps search around for advice on how to check it. Best I can think of is to take sound shield off the bottom and then open the air intake connection to see if oil spills out (on mine there is no volume of oil, but there are drips).
03 Jetta TDI 5-spd 310k mi PP520 Nozzles, IQ 5.8
13 Prius 125k mi
16 Civic 1.5L turbo (29k mi) ~ 37 mpg
mk3 is offline   Reply With Quote
Old November 19th, 2018, 04:44   #9
Genesis
Fuel Economy: 53/48/42
Mine used to consume near-zero oil over a 10k mile interval.
Now it does consume some. A small amount leaks (back of the valve cover-to-head area, as with many) and since the gasket is not replaceable on the cover I've done some RTVing there, but it still does leak a small amount. The rest is likely going down the valve guides since when I pull the lower charge air pipe there's only an oily film and no build-up in there.
Since the cam and visible surface of the lifters looked fine at last timing belt interval I left it alone. Next time around (engine has ~250k on it) I'll likely pull the head and have it reconditioned, along with doing the oil pump drive since a failure there can be catastrophic. If the turbo continues to bypass almost no oil and still has no problematic play in the shaft I'll leave it alone. I might also buy a replacement valve cover (so as to get a new, and non-leaking gasket.)
Genesis is offline   Reply With Quote
Old November 19th, 2018, 06:02   #10
~TDIguy~
Fuel Economy: I just know I drive past alot of fuel pumps
That sounds like alot cause i run 10k mile changes with no top ups! 175k miles with stage 4. But hey if the other guys say your cool roll with it, mine is a bew, the ALH may be different ive never owned one of them.... Oh btw maybe you need some better oil, I am an amsoil dealer..............
~TDIguy~ is offline   Reply With Quote
Old November 19th, 2018, 07:07   #11
McGuillicuddy
Thanks everybody for responding (except that one guy). I should mention that I am using Rotella T6 5W40 and use a 10K km (6250miles I guess) oil change interval. I haven't sent it in for a UOA but I might do that soon. I also have not yet checked the intake for oil so I will do that ASAP.
'The Battle Wagon'
Old November 26th, 2018, 09:07   #12
KyleMillione
Fuel Economy: 02 (auto) 39, 03 (man) 48
I’d check the back of the valve cover as well. The “built in gasket” in the valve cover becomes built in plastic in short order, then leaks all down the back of the block.
2002 Green Jetta Auto 220k RIP
2002 Black Jetta Auto 240k
2003 Silver Jetta 5sp 290k
KyleMillione is offline   Reply With Quote
Old November 26th, 2018, 11:20   #13
How many kilometers on the engine? As these engines wear they tend to lose a little oil through the valve guides and seals when the car sits. They burn it off when you start up, usually making a puff of blue smoke.
A quart in 4,500 miles isn't ideal, but it's not terrible, especially if you have over 250K miles on the car. All my TDIs, except for the brand new ones, have used a little oil between changes. But I agree to look for leaks. That may be what you smell.
2002 Jetta wagon, 397K, RC3+; 1993 Mercedes-Benz 300D 2.5, 197K; 1997 Passat, 289K; '99.5 Golf, 260K; 2011 335d, 63K; 2015 Golf Sportwagen, 13K. Principal, http://www.idparts.com
Old November 26th, 2018, 14:48   #14
eddieleephd
Fuel Economy: 38mix / 47@70-75
How fast are you driving it to use that much oil. Oil consumption is often relative to speed and how hard you drive it.
I had a Nova that would burn a quart every 1500mi at 65-70, however, it used a quart every tank running 75-80.
My ALH might burn, vent through pcv a quart per 10,000 mi interval. I usually don't run over 75 and 65-70 on average leaning towards 75, occasionally 80-90, or so to pass, or maybe just because
I would guess at an 80 average it might increase a bit.
'02 1.8t Jetta Wagon Alh w/5spd swap, SB 21#SM DD, bew lift pump, 11mm IP, VNT17, Malone stage4 tune, Stealth pipe, BMW Cyclonic CCV filter, 2.5"cat back st. pipe,Vr6 brakes, 2" lift, Panzer, Bilstein HD, fill tube ectomy, soon to be Wuzetem p.520 PD_fuel_delivery TDI Search Plug release tool Howto terminal release tools VW/Audi
eddieleephd is offline   Reply With Quote
Old November 27th, 2018, 07:45   #15
McGuillicuddy
My car only has 136K kms on it (85K miles). I drive the car daily (75miles round trip, all highway) but it obviously spend a lot of time sitting unused in its past until I bought it earlier this year. It was literally owned by a little old lady and her husband (until he died - which I can see from the service records when the name changed from his to hers ).
'The Battle Wagon'
Oil consumption during first 8000 miles, what's normal? 03_01_TDI VW MKVI-A6 Golf family including Jetta SportWagen (~ 2010-2014) 20 September 29th, 2013 16:13
Oil Consumption in 10,000 miles Knoxville TDI 101 27 August 10th, 2008 07:51
Oil Consumption Concern? DezlDan VW B5 Passat TDIs 9 December 14th, 2005 10:30
Oil consumption during first 5k miles? Alex_Scheler VW MKIV-A4 TDIs (VE and PD) 6 November 25th, 2003 13:08
Oil Change Concern at 650 miles... Drizzten Fuels & Lubricants 6 September 7th, 2001 04:20
Page generated in 0.23854 seconds with 11 queries
[Output: 126.94 Kb. compressed to 106.23 Kb. by saving 20.71 Kb. (16.32%)]
