Old November 15th, 2018, 22:05   #1
DieselDuberrr
TDI(s): 03 Jetta
Default Vibration after mount change
guys,
had some issues with vibration on gear changes and when lifting off the throttle. I changed the dogbone, trans mount. When I was doing the drivers side, I noticed the engine had dropped. So investigation revealed that the rear mount ear had broken off. I repaired this with the dieselgeek mount fix.
Anyway now I have a different kind of vibration. When I accelerate I get vibration through the steering wheel and pedals etc.
I am hoping that I failed to align the mounts correctly. Is this something that could cause that? Before i changed the mounts there was no vibration when accelerating. It only happens when i get above 2700 ish RPM.
My other thought was drive shaft, or CV etc... but then i was thinking why would that start now all of a sudden.
This is the last thing enabling me to actually get this on the road.
DieselDuberrr is offline   Reply With Quote
Old November 16th, 2018, 03:40   #2
eddieleephd
Fuel Economy: 38mix / 47@70-75
Take it in to get the wheel balance and alignment checked. Better to be sure than run in circles chasing ghosts.
Stiffer mounts can transmit more vibration as well.
'02 1.8t Jetta Wagon Alh w/5spd swap, SB 21#SM DD, bew lift pump, 11mm IP, VNT17, Malone stage4 tune, Stealth pipe, BMW Cyclonic CCV filter, 2.5"cat back st. pipe,Vr6 brakes, 2" lift, Panzer, Bilstein HD, fill tube ectomy, soon to be Wuzetem p.520 PD_fuel_delivery TDI Search Plug release tool Howto terminal release tools VW/Audi
eddieleephd is offline   Reply With Quote
Old November 16th, 2018, 05:55   #3
HamtramckDiesel
Fuel Economy: 48.7 mpg
It could also take sometime for the mounts to "break-in". Also, it sounds like you you just could have bad tires, rotors, or other suspension issues. Like eddie said. Take it in for an alignment.
HamtramckDiesel is offline   Reply With Quote
Old November 16th, 2018, 06:38   #4
steve6
...and if you installed any kind of Poly mounts expect more vibrations
steve6 is offline   Reply With Quote
Vibration-mount issue? T.W. VW B5 Passat TDIs 8 June 28th, 2016 16:57
More vibration after changing Motor Mount xFlandies TDI 101 11 January 4th, 2016 23:24
dogbone mount finished, now theres a vibration Cleaner13 Upgrades (non TDI Engine related) 6 May 7th, 2010 14:58
Extra Engine vibration. Motor mount? NRU73 VW MKIV-A4 TDIs (VE and PD) 0 April 5th, 2006 08:54
Engine mount vibration carlisle VW MKIV-A4 TDIs (VE and PD) 15 July 13th, 2004 05:36
Page generated in 0.11424 seconds with 11 queries
[Output: 62.34 Kb. compressed to 55.94 Kb. by saving 6.40 Kb. (10.27%)]
