Old November 15th, 2018, 06:41   #1
starjays
TDI(s): 2000 NB 5MT
Fuel Economy: 42
Default Sway bar size, 21 or 23 mm?
Hi,
I'm looking to order some sway bar bushings from IDParts and they have a few different options. Would anyone be able to tell me what size sway bar I would have on my 2000 Beetle? They give options of 21 mm or 23 mm.
Thanks!!
starjays is offline   Reply With Quote
Old November 15th, 2018, 08:20   #2
JB05
Fuel Economy: 43/41/40
An open end wrench makes a good measuring tool for the sway bar.
JB05 is online now   Reply With Quote
Old November 15th, 2018, 08:33   #3
oilhammer
oilhammer's Avatar
Fuel Economy: fantastic
Yep, that is what I use too.
oilhammer
www.cardocautomotive.com
Old November 15th, 2018, 09:23   #4
mjydrafter
mjydrafter's Avatar
You really must measure.
Also, if you're in the rust belt, you may have to account for some rust scale.
Also, even with the correct size you'll think they are wrong when you go to replace them. I just did them on my son's 2000 Jetta (21 mm BTW).
Make sure you have the correct brackets as well. The newer bushings won't work with the old (flat) brackets.
mjydrafter is offline   Reply With Quote
Old November 16th, 2018, 09:57   #5
starjays
TDI(s): 2000 NB 5MT
Fuel Economy: 42
Thanks for the input. I called the dealership in Omaha and gave them the VIN and they told me they're 23 mm, so that's what I ordered. Fully planning on things not working-out, so if by chance they do, well, maybe I'll build myself a cake or something to celebrate.
Old November 16th, 2018, 19:15   #6
Prairieview
Both of my 2000 Beets have 23's.
Prairieview is offline   Reply With Quote
Old April 2nd, 2019, 14:36   #7
1975 Kombi
Ya I'm in the process of doing mine and the rust scale is to the point that the bushings will not fit. I will remove the rust scale tomorrow and give it another try.
1975 Kombi is offline   Reply With Quote
Old April 2nd, 2019, 18:38   #8
[486]
TDI(s): 02 golf ALH
protip, hammer takes scale off better than any abrasive
[486] is offline   Reply With Quote
APR/Hotchkis 27 mm adjustable rear sway bar MK6 swmic Private TDI Items for Sale/Wanted 2 June 20th, 2018 12:09
Sway bar bushing replacement/ what bar size on 2006 Jetta TDI BioJetta2001 VW MKV-A5 Golf/Jettas 8 July 10th, 2015 18:18
22mm or 25 mm H&R rear sway bar?? parkair Upgrades (non TDI Engine related) 9 March 1st, 2008 06:42
97 Jetta TDI / 17 or 19 mm sway bar?????? bchezick VW MKIII-A3/B4 TDIs 2 January 29th, 2008 09:50
21 mm vs 23 mm front sway bar? Noticeable differences? TDIMeister Upgrades (non TDI Engine related) 5 September 19th, 2002 09:47
Page generated in 0.14719 seconds with 11 queries
[Output: 82.93 Kb. compressed to 71.43 Kb. by saving 11.50 Kb. (13.87%)]
