Old November 16th, 2018, 17:53   #16
engineerchad
TDI(s): 02 Jetta
Okay I'd seen the oven suggestion are we talking as hot as it can get?
engineerchad is offline   Reply With Quote
Old November 24th, 2018, 05:54   #17
eddieleephd
Fuel Economy: 38mix / 47@70-75
500ish heating up the metal causes expansion and contraction at different rates due to densities and sizes. You'll often see it started to stick a housing in the oven and drop the cold bearing in easily opposed to driving in.
A little heart can work wonders.
'02 1.8t Jetta Wagon Alh w/5spd swap, SB 21#SM DD, bew lift pump, 11mm IP, VNT17, Malone stage4 tune, Stealth pipe, BMW Cyclonic CCV filter, 2.5"cat back st. pipe,Vr6 brakes, 2" lift, Panzer, Bilstein HD, fill tube ectomy, soon to be Wuzetem p.520 PD_fuel_delivery TDI Search Plug release tool Howto terminal release tools VW/Audi
eddieleephd is offline   Reply With Quote
Bew to alh swap gstone TDI Conversions 22 January 9th, 2019 14:15
ALH to BEW swap? r3dplanet VW MKIV-A4 TDIs (VE and PD) 5 June 19th, 2017 08:41
bew to alh swap? btketterer VW MKIV-A4 TDIs (VE and PD) 5 January 14th, 2016 10:24
bew to alh swap btketterer TDI Conversions 5 April 9th, 2015 09:02
Swap AlH -> BEW Benjamin_VW Quebec 3 May 16th, 2007 08:17
Page generated in 0.14077 seconds with 11 queries
[Output: 53.35 Kb. compressed to 49.33 Kb. by saving 4.01 Kb. (7.52%)]
