Old October 3rd, 2014, 08:49   #1
NOLAHusker
Default Dashboard Light Dimmer Switch Smoking
2003 Jetta Wagon
Well, I had a bit of a scare on my drive home this morning. The dashboard light dimmer switch started smoking as I was driving down the highway. I figured out to turn off the headlights, and that killed the smoking, but I obviously can't drive this thing at night any more.
My question, of course, is what should I do about this? It seems as if the obvious solution for this is to change out the switch. I just want to make sure I don't need to check anything else.
Thanks!
NOLAHusker is offline   Reply With Quote
Old October 3rd, 2014, 10:26   #2
vanbcguy
vanbcguy's Avatar
Change the switch for an immediate fix.
Look for a headlight relay kit if you want a permanent fix. They are fairly inexpensive. What the relay setup does is route the high current power for the headlights through the relay rather than through the headlight switch. The result is brighter headlights since the power no longer needs to go on a circular route through all the connectors and cabin wiring back to the engine bay, plus the headlight switch will never wear out again since it doesn't have to work very hard.
My build thread: http://www.vwdiesel.net/forum/index.php?topic=32967.0
vanbcguy is offline   Reply With Quote
Old October 4th, 2014, 11:02   #3
NOLAHusker
Thanks. Changed out the switch this morning and there seem to be no issues. Given that it had 201,000 miles on it, I don't know if I want to invest the time and energy in installing the relay.
Appreciate the advice, though. I'll see just how much work it might be.
Old October 4th, 2014, 20:35   #4
vanbcguy
vanbcguy's Avatar
If you can find a kit it is literally as simple as plugging one of the headlight connectors in to the relay harness, plugging the harness in to the headlights and connecting the harness positive to the battery positive. Took me all of 10 minutes on my car.
Old October 4th, 2014, 20:37   #5
vanbcguy
vanbcguy's Avatar
Specifically look for a kit like this: http://m.summitracing.com/parts/upd-34263
I have NOT checked to see if this is the right one, I just did a quick google search, do not order this kit without checking on the connectors first!
Old October 4th, 2014, 23:00   #6
Dimitri16V
Dimitri16V's Avatar
the switch won't smoke , wires will. you have high resistance somewhere
2004 Golf TDi 412K, 87 Rocco
2016 Toyota Corolla S
2016 Golf TSI ( reinforced metal oil pan , VCDS tweaks)
Aleksander Prokhorenko , Charles Keating ,Russian and US special forces KIA against ISIS. RIP heroes
Dimitri16V is offline   Reply With Quote
Old October 9th, 2014, 08:53   #7
NOLAHusker
It was definitely the switch smoking. The body of the switch was warped from the heat, and there are no wires adjacent to the side of the switch that could cause that.
Old August 1st, 2015, 09:24   #8
mrGutWrench
mrGutWrench's Avatar
Fuel Economy: 63 MPG/56/47 (2nd tank) '02 Sedab
Let's be specific here. Are you talking about the little instrument light dimmer switch (a little wheel-type dimmer), the lighting/headlight master switch (round, about 2" in diameter, with 2 little headlight icons on the top edge of it), or the headlight dimmer/turnsignal switch on the steering column?
It was my instrument light dimmer that fried (you can see burnt areas in the adjustment wheel) and smoked. That was on Wednesday night. A friend had a spare used one and I put that in and the lights still don't work. Both the 5-amp fuses are good. I don't have a good feeling about this.
'03 Jetta Wagon, TDI - ALH, 370K miles
MrG, Wallace NC (2002 Jetta, Totalled by drunk, 11/'06; 130K mi in 4 1/2 years/~57 MPG lifetime); New car, '03 Jetta Wagon, CAT filter, .681 top gear, 350K mi. in 11 1/2 yr, ~52.
mrGutWrench is offline   Reply With Quote
Old August 8th, 2015, 08:03   #9
mrGutWrench
Originally Posted by mrGutWrench View Post
L ... A friend had a spare used one and I put that in and the lights still don't work. Both the 5-amp fuses are good. I don't have a good feeling about this.
Is there a relay in this system? I have power at/through both 5-amp fuses in the fuse panel next to the driver's door but no power at the central terminal of the connector to the rheostat dimmer. Everything (taillights, brake lights, interior lights - except for the instrument lights and heater control lights, headlights, etc.) all work OK. Just no lights on speedo/odometer.
Thanks, MrG
Old November 10th, 2017, 14:36   #10
cjz
cjz's Avatar
Bumping old thread . . .
I had the same issue with my MKIV Jetta.
The dimmer switch fried and instrument cluster won't light.
I ordered a new switch and just hooked it up - but lights are still out
(dash cluster, radio lights). Fuses are fine.
Tail lights and turn signals are fine.
Did you ever find the root cause?
cjz is offline   Reply With Quote
Old November 11th, 2017, 18:53   #11
wonneber
Was you control melted like in the thread?
You need the headlight switch on to check this.
Fuse 3 is the one for the dash & such lights, not sure if 04 is different. It's 5 amps.
Power to the dimmer control is a gray wire going to pin 2. It's gray with a blue stripe
It feeds the lights from pin 3
Pin 1 is the ground, its brown.
If you have power going out you have to follow where it's lost.
No power follow the wire to the fuse box, then from there to the headlight switch.
Old November 12th, 2017, 18:49   #12
cjz
cjz's Avatar
I appreciate the response.
Yes, the control switch melted and I am still troubleshooting.
I will have to get out my multi-meter and start checking.
This happened immediately after I replaced the driver side fender liner.
I thought maybe I pinched some wires - took it off and it looked fine.
The signal light on the fender still works.
Old November 15th, 2018, 03:30   #13
badgervwman
Fuel Economy: 30 MPG
I had the same problem last night I was just driving home then smelt something burning like plastic and I saw the dimmer switch arching and smoking inside. I had literally smoke coming out the vents. Very surprised the fuse didn't pop first, I quickly pulled into a parking lot and took out the switch. I think I might know why there's high resistance I was using the heated seats at the time when this all happened. I'll have to check the schematics I'm thinking the heated seats run on the dimmer switch side the fuse checked out good. Really hoping the power feed to the heated seats didn't short out the dimmer switch which could be a possibility.
***If you have the seat heaters on don't set them very high or the dimmer switch will ark and short out*** This really should be addressed and reviewed by VW for a TSB recall.
badgervwman is offline   Reply With Quote
Old November 15th, 2018, 14:36   #14
BobnOH
not-a-mechanic
Fuel Economy: 50/45/35
What model/year is your car badger? Haven't seen many of these failures on these forums.
Old November 16th, 2018, 01:38   #15
badgervwman
Default Dimmer Switch Up In Smoke
Hi BobnOH, I have a VW 2003 Jetta 1.8T GLS, the burning plastic really lingers I'll have too double check for chard wires.
OEM+ Dashboard Dimmer With Headlight Leveling Control passattimmy Private TDI Items for Sale/Wanted 25 April 11th, 2014 01:30
Dimmer switch Westro VW MKIV-A4 TDIs (VE and PD) 3 March 13th, 2009 07:00
Dimmer switch Sebpt VW MKIV-A4 TDIs (VE and PD) 3 January 19th, 2009 08:06
Switch or new blank for dashboard next to hazard light JimO TDI 101 3 January 6th, 2006 06:06
03 Jetta dashboard dimmer-switch problems [OT] ajit TDI 101 4 November 27th, 2002 08:33
Page generated in 0.16257 seconds with 11 queries
[Output: 126.36 Kb. compressed to 105.20 Kb. by saving 21.16 Kb. (16.75%)]
