J jason_ Veteran Member Joined Jun 2, 2014 Location michigan TDI 2015 s wagon dsg Dec 7, 2017 #1 Did vw offer? I have the s trim on the wagon. Sent from my One using Tapatalk
Jetta_Pilot Top Post Dawg Joined Apr 14, 2005 Location West Hill, Ont. TDI 2015 Passat Highline TDI Candy White (SEL Premium) long gone 2002 Jetta TDI Dec 7, 2017 #2 jason_ said: Did vw offer? I have the s trim on the wagon. Sent from my One using Tapatalk Click to expand... Did your car not come with a starter? Do you have to hand crank it?
J jason_ Veteran Member Joined Jun 2, 2014 Location michigan TDI 2015 s wagon dsg Dec 7, 2017 #3 Remote Sent from my One using Tapatalk
J jason_ Veteran Member Joined Jun 2, 2014 Location michigan TDI 2015 s wagon dsg Dec 7, 2017 #4 https://parts.vw.com/p/Volkswagen_2016_Passat/Passat-Remote-Start-Kit/63614949/561065760B.html Sent from my One using Tapatalk
VeeDubTDI Wanderluster, Traveler, TDIClub Enthusiast Joined Jul 2, 2000 Location Springfield, VA TDI ‘18 Tesla Model 3D+, ‘14 Cadillac ELR, ‘13 Fiat 500e Dec 7, 2017 #5 You're posting in the wrong place. This is the Passat forum. You will have to find an aftermarket solution if you want to retrofit remote start onto your S trim Sportwagen. There are no OEM options available. moderator note: thread moved.
J jason_ Veteran Member Joined Jun 2, 2014 Location michigan TDI 2015 s wagon dsg Dec 7, 2017 #6 What makes the passat able to have remote start and not a golf? Is the starter different? Seems all it needs is some vcds, receiver, a remote with another button, and relays. Sent from my One using Tapatalk
