Not sure which engine yours has. My 14 Passat is supposedly not compatible with biodiesel. The warranty is void if you use anything more than a B5 or something like that, (except Illinois?) but beyond warranty issues, I was under the impression that it is to be avoided. I do run it in our 06 Jetta, and burn thousands of gallons on the farm, but not in the new rig.
You should change your fuel filter right away, just to rule that out.
Sent from my iSomething using Tapatalk
Please forgive typos and commas
Correct, except Illinois and Minnesota (no others so far that I know of).
Owners of MKVI's in these two states have received letters that state VW will honor warranties with the use of up to B10 in IL (I think....IL people may correct this if it is wrong) and up to B20 in MN. Just have to watch the oil level.
Also, I have not noticed a drop in mileage since it changed over to bio. In fact, my record tank came using it, at over 54 mpg. Now that the weather is cooling off though.....normal hit in mileage to follow.
BeachBum-
I would consider 35mpg horrible for highway cruising. I have about 75% highway driving, and cruise at 70-80mph. I'm not out blowing the doors off of people, but I'm not hyper-miling, either. Just pretty much sensible, normal driving. If my FE was that poor, I'd be finding out what is wrong. Break-in does not account for it, or at least mine never did that poorly during early break-in. I think the effect of break-in on FE was more pronounced on pre-CR engines.
I'll leave it to those with DSG to comment on the difference that may make.
