fruitcakesa
I know chasing down these kind of noises can be frustrating and this one is no exception.
Running over my gravel road it will occur, although it is inconsistent.
It almost never happens when on the highway.
This is a lighter sound, not really a clunk.
My 02 wagon had a similar noise that turned out to be the lower shock mount bolt which had a tiny bit of play that caused the rattle, which I remedied with some black tape wrapped around the bolt.
I have replaced rear shocks, springs and mounts [they were due].
The only thing left back there are the axle beam bushings and the car handles fine with no twitchy behavior.
From what little I can see of them they appear to have tiny cracks in the rubber but they appear to still be intact.
Could worn bushings "rattle"or would they make a "heavier" sound?
Any other advice or ideas?
