05 passat problems
DeliveryValve
Western US
Passat GLS Wagon
What codes are you getting on the VCDS?
It could be a number of things like a bad N75, stuck VNT, leaking vacuum lines, etc.
bako
kern county
passat wagon
05 passat wagon
have a problem when the car starts up a hill the check engine light comes on. scan it says turbo over boost then it goes into limp mode turn the key off reboot runs ok agian until you gas it hard anybody have any idel whats up
Lug_Nut
Sterling, Massachusetts. USA
No, but I have exactly the same symptoms.
If I drive for 15 seconds or so (100 yards the other way and turn around) before trying the hill, no problem.
If I use tip mode and hold gear until 3k rpm, no problem.
If I try to brake-stand (foot on the brake AND hard accelerator pedal application) for about 5 seconds, then drive normally in full auto, no problem.
If the car has already been driven that day, no problem.
If I use full auto and WOT, no problem.
Let me know if you find any solution.
bako
kern county
passat wagon
The only code that came up was turbo over boost and the emission light comes on goes in to limp mode turn off restart runs ok.up a hill or hard acceleration it goes into limp mode.
vwztips
Greenville, SC
2005 Passat GLS Wagon TDI 5 spd manual w/BSM delete 2011 Tiguan TDI/DSG 2005 Audi A4 Avant 6MQ TDI 2011 BMW X5 35d
I have not had this problem on my Passat TDI but have had it with 1.8t's and it was definitely the N75 causing my non-chipped 1.8t to spike to chipped boost levels and then go into limp mode rather abruptly.
Lug_Nut
Here's the start of this request:
http://forums.tdiclub.com/showthread.php?t=329908
Replacing my N75 did not change my cold start, moderate hill within 30 seconds of start limp mode.
If the car idles for about 45 seconds before I attempt the hill, of if I floor it through 1, 2, and 3rd gear going up, or I use manual tip mode and delay shift to 3000 rpm, there is no limp. No, the N75 is not my culprit.
other posts of my identical problem:
using "limp" as the key word:
post #5 here: http://forums.tdiclub.com/showthread.php?t=234520&highlight=limp
When I thought I had it fixed post #13 here: http://forums.tdiclub.com/showthread.php?t=239430&highlight=limp
Still 'fixed' in post 27 and 33 here: http://forums.tdiclub.com/showthread.php?t=253126&highlight=limp
and here in post #13: http://forums.tdiclub.com/showthread.php?t=311117&highlight=limp
using "tip" as the key word:
post 2 here: http://forums.tdiclub.com/showthread.php?t=263718&highlight=tip
post 25: http://forums.tdiclub.com/showthread.php?t=245900&highlight=tip
posts 18 and 22 here: http://forums.tdiclub.com/showthread.php?t=243804&highlight=tip
Some of those make it look like the problem is solved? Nope. It was gone for a few months then came back.
tlbo
Dallas, TX
2005 Passat, 1996 Passat
'Limp mode' syndrome
I too have the 'limp mode' syndrome, except mine will accelerate slow, then accelerate as normal, left in Drive it will sometimes take longer to go through the gears, if done in gear mode, does fine in the acceleration, for a hill, change to the gear mode, and let it climb naturally may loose 2-5 mph's. If you push toooo hard then it will go into 'limp mode'.....no fun turn on 4-ways so will not get run over...... Did ask VW dealer about the issue......shop foreman, tech, and instructor has NO idea on what would cause the issue except, a $1500 ECM (Electronic Control Module), that being a 50/50 chance THAT MIGHT FIX IT............ At first got the car back it would act like it was being starved of fuel......sucking air......fuel filter.......it then asked me to STOP at that time I did, so I could try again. Now it start every time, except for today twice it baulked - not as long as the other times - but started....Of course I did try to convince VW (Park Cities/Boardwalk) that something else was the issue.... I work on PC's just trying to show them (VW) on thinking outside of only what the manual states........ So does anyone have a better thought about the 'limp mode' issue. I reside in the DFW area and someone has mentioned in a post about a good TDI mechanic in this area, does any one know? Currently I am chained, but will drive slow and have that DFW mech do the fixin'......
s4phillips
Live in d/FW, TX. Transplanted from the Pacific
2002 Beetle, 2005 Passat Variant-DOA blunt force trama, 2014 Beetle-went home
snip... So does anyone have a better thought about the 'limp mode' issue. I reside in the DFW area and someone has mentioned in a post about a good TDI mechanic in this area, does any one know? Currently I am chained, but will drive slow and have that DFW mech do the fixin'......
Look in this thread for DFW area shops that work on VW TDIs and have experience with BSM replacement/upgrade: http://forums.tdiclub.com/showthread.php?t=293773
You might also contact a member here that goes by jetta ,97 for diagnostic help. You can find many of his posts and reviews of his work in the Meetings/GTG/Regional Discussions ->South Central Regional States section. I have no personal experience with any shop as I have done everything myself except for one re-flash for one of the glow plug changes.
I have to think these limp mode events are caused by leaking vacuum hose or connections, a charge hose leak on the intake track, bad N75 valve, sticking vanes on the turbo, or perhaps the tandem pumps is not creating the proper vacuum when cold.
