MotorCityMadman
So I assumed the 540k km transmission was done but I thought I would try and revive it for a bit. The symptoms are uncommanded lock up in all gears including R. This may or may not occur at start up and initial movement.
What has been done: shift kit in attempt to alleviate symptoms, another vb and solenoids (all test perfect), a new transmission harness, another tcm.
When reviewing a troubleshooting pdf it indicated that if you disconnect the harness from the transmission and get fail safe mode then the trouble is electrical. This is what occurs. R, 1st, and 3 work with the harness disconnected. It does not lock up at all with the harness disconnected.
This would lead me go believe it was a car wiring issue. Maybe the wire to pin 6 is grounding out? Unfortunately I cannot get pin 6 on the car side to short to ground when wiggling the wiring harness from trans to the tcm.
Anybody have any ideas?
