scotty_rabbit
Hi guys, Thought i would get a thread going. I am going to pick up my AHU Lump in a couple of weeks, its coming with everything except the pedal box and cable shifter. Everything else is coming....
Well here it is when i got it.
when i got it
after a clean
Mr friend helping out
I had to replace the rear penal as it was damaged,
Also a repair to a badly damaged sill.
And maybe the choice of wheels once the engines in
So..............
Next up is the engine. I will have loads of questions as its my first tdi conversion.
Just a couple to start.
If i dont use the cat, will i get errors codes that will make the engine run in limp mode??
Any ideas whats going to happen with the mounts? Its a 1.1C, so its got the drivers side mount further back than the GTI version....
Many thanks, Scott
when i got it
after a clean
So..............
Many thanks, Scott
