Old July 11th, 2019, 13:52   #1
GoodOak
Default Dashboard, running cables under & screwing things into
I'm looking to install a Scan Guage and a Ram Mount to mount my phone in on my dash. For both, I would like to run the cables under the dashboard or otherwise hide them so they are secure and not visually cluttering up the dash (any more than the interments they are attached to do!). For the Ram Mount, I'm probably going to use some self-boring screws to mount them to the dash.
Does anyone have any tricks for getting wiring under the dash? Can any panels be easily removed to make this easier?
Am I at risk of puncturing anything if I screw into the top of the hood over the instrument panel?
GoodOak is offline   Reply With Quote
Old July 11th, 2019, 14:35   #2
TDI Kovács
TDI Kovács's Avatar
Why not use some good double sided tape to hold things down instead of putting holes in the dash?
https://www.rammount.com/part/RAP-B-378-UN7U
Or the suction cup to the windshield version?
https://www.rammount.com/part/RAM-B-166-A-UN7U
You just cannot turn back after drilling holes.
2012 Volkswagen Golf TDI 2DR 6MT United Grey
2014 Volkswagen Jetta Sportwagen TDI DSG Platinum Grey
2014 Volkswagen Jetta Sportwagen TDI DSG Reflex Silver
TDI Kovács is offline   Reply With Quote
Old July 11th, 2019, 19:32   #3
GoodOak
Originally Posted by TDI Kovács View Post
Why not use some good double sided tape to hold things down instead of putting holes in the dash.
I did also pony up for the adhesive base. But it has been my experience in the past the adhesive mounts for this sort of thing wobble and vibrate a lot. And or fall-off eventually. I will give it a go, but screwing into the dash has worked well in my other vehicles.
Old July 12th, 2019, 09:11   #4
pmm
don't screw anything into the top of your dash, you might regret it and it's not necessary.
Remove your A pillar and run any cables down the side and under your dash that way.
2013 JSW TDI 6MT
pmm is offline   Reply With Quote
Old July 21st, 2019, 10:13   #5
GoodOak
I have screwed things into the dash boards of two other vehicles I own and I can assure you I have zero regrets.
So, does anyone know a good way to run a cable under the panels from the cigarette lighter to the base of that driver's side A pillar?
Sent from my iPhone using Tapatalk Pro
Old July 21st, 2019, 10:14   #6
GoodOak
Tried this. Fell off the first time we used it, as expected.
Old July 21st, 2019, 10:56   #7
TDI Kovács
TDI Kovács's Avatar
Well, I guess you're next step is to put holes in your dash.
Guess if you ever sell, it'll only cost just over $1200 for a new dash to replace the holey one.
Old July 21st, 2019, 11:14   #8
GoodOak
By the time I sell this car the holes in the dash will be the least of its problems.
Starter & Cables ratkc135 TDI 101 34 January 28th, 2019 19:41
Tell Us About Your Running Swaps: Mileage Racked Up,Impressions,Things You Would.... G60ING TDI Conversions 66 August 4th, 2017 16:08
where to run Amp Cables mattds VW MKV-A5 Golf/Jettas 2 July 19th, 2011 16:44
Where to Mount an Amp? Run Cables? Hank101 VW MKV-A5 Golf/Jettas 9 July 29th, 2010 11:53
Wanted: VAG-COM & Cables Herm TDI Private TDI Items for Sale/Wanted 3 February 17th, 2002 11:13
Page generated in 0.15322 seconds with 12 queries
[Output: 86.52 Kb. compressed to 74.60 Kb. by saving 11.92 Kb. (13.78%)]
