A few weeks ago I noticed the fuel lines in between the injectors were leaking so I replaced them and they started leaking right away again. So as the car was running I pulled the small return line off the injector pump and fuel was coming backwards out of that pump with a stream. Talked to Frank Irving about this problem and he thought it was a bad pressure issue. I replaced the T going into the fuel filter and I checked to make sure the fuel line going into the tank was not clogged. It is still doing it. As the car was running I pulled the return line off after the injector line and before the filter and it was coming out properly so I pulled the little fuel line coming before the pump and the fuel was still coming backwards out of the pump. The funny thing is the car still runs for the most part fine but just lacks power.
