Well, now you are even MORE familiar with the BRM
The KW adjustment won't be right unless the tool is used, you can guess and get it close (I guess, I don't know, 'cuz I don't guess
The CMP sensor gets adjusted to the CKP. If the CKP sensor is off, then of course the CMP is off. Since the EDC16 system is not really very good at setting DTCs for this sort of thing, it may not be obvious that it is even off. Seems many people here do not even know the KW setting even exists (like STARWARSTDI
) but of course we know it indeed does.
I got my T10134 for only $100 used, but that was a rare deal.
Only way you'd know for sure if you got the seal carrier installed correctly would be to check the KW before and after... if it changed at all, it is NOT lined up correctly.
