It does not work on the GSW without modifications, which are fairly easy. I've had mine for a few weeksfunny, the towready web site says the #118646:
Fits Vehicle Style:Except GTI & Sportwagen Models
willie
on the diesel-sippin' Gulf of Mexico
willie
Same connector, but it is wired differently for a GSW. I would still go that route, and tap into the tow ready harness vs tapping into the factory wiring.What is the difference between the standard golf and the sportwagon for tail light wiring?
So does the Stealth unit, and it is snugger and higher so you won't crash the damn thing into the ground every driveway or speed bump like the Draw Tite.The Westfalia drops right in.
We don't have the "tow ready harness"?https://www.westfalia-automotive.co...h__Default_/03_WAM_Katalog_2017_GB_OP_web.pdf
Look on page 246 of the pdf. The ones labeled Kit include the wiring. You need the kit without preliminary set up since a Canadian GSW probably isn’t pre wired for the module. My US Golf was not.
Removable Hitch by itself. 321 782 600 001
Kit with same hitch and trailer wiring 321 784 900 113
Out of stock sadlyUsually If you buy from Amazon.de, they’ll remove the VAT, so the price will be 19% cheaper than what’s listed. You’ll then pay the shipping on top of that. You won’t see the real price until you start to check out.
As long as the part number is correct, I wouldn’t worry about what years Amazon thinks it’ll fit.
I really like the oem wiring, and it’s easy to adapt it to a fully functional US 7 way with functioning 12v power and reverse lamp outputs.
Edit: Amazon is no longer taking off 19% off. When I put in the cart, it shows up for €200 + €71 which ends up at $346 shipped.
Edit 2: Because of Brexit and the exchange rate, Amazon UK is cheaper than DE right now. The prices on both are way up since I bought my hitch and wiring in May.
https://www.idparts.com/bosal-swan-neck-trailer-hitch-mk7-golf-sportwagen-p-5570.html
Id Parts has the Bosal. Functionally it’s the same as the Westy. I might have ordered from them, but wanted the kit with the wiring.
what my guy used and tapped into the wires on a wagen. was for a Mk6 that he found on the local buy sell
https://www.amazon.ca/Tow-Ready-119190-Integrated-Protection/dp/B001P2DULI
