same direction as on AEL, AHY, ACV, etc.You have head 13mm left rotation?
is this 13mm direct fit? do you have any feedbacks regarding 13mm+ dss ultime II nozzles? + turbo?same direction as on AEL, AHY, ACV, etc.
Anyone have a suggestion on what mapsensor i can use? That wil fit?
Have you guys been aware of this one?: http://shop.vems.hu/catalog/sensor-brassnipple-p-121.html?osCsid=1ff09b906809d021520740e26929b09aI had the same problem with the map sensor...
couldn't find anywhere... maybe it can be built by a solderer.
maybe take any kind of 4bar sensor & adapt it to your wires?
I had the 3bar version on my AHU with 2056vk...for 68 pin msa15 you can also use the small smd type sensor, then you can mount it in the ecu like stock
Yes, I'm also very interesstedMaybe we could get a own 2.5 aat/ael group on the forum? i think we need it
lol... didn't know that back then...That´s normal for Coolingmist pressure switch. There is no such problem on Devilsown pressure switches.
K is plunger end clearance, correct?Anyone has info for china 12mm pump head k-setting? I did ask orginal 10mm pump head k-setting from diesel wokshop and they say it is 2.6mm. Replacing 10mm head to 12mm head k-setting jumps to 3.1mm.
Yes.The Borg Warner EFR series is state-of-the-art for wastegate turbo's in the market, but the price reflects that. But for the price you get:
Garrett's GTX series basically equals the EFR im most features, but the EFR maps seem to push higher PR, which is desirable for a Diesel.
- Mixed Flow Gamma-Ti turbine wheel
- Forged milled extended tip compressor wheel
- Military-grade dual ceramic ball bearing assembly with silver plated metal cage
- Stainless steel turbine housing
- Water cooled light-weight Aluminum bearing housing
I would consider either to be the ultimate choice.
Sounds like something I would write, but it's true - there no point to have a twin scroll in an odd-number cylinder engine.But as much as Ive read on forums, you couldnt get twinscroll turbos working on a odd number of cylinders. And a single scroll Holset would problably spool in high range rpm...
