Well, any used pump could be defective. Not sure where you are, but finding a used injection pump in Atlantic Canada with only 150,000 kms on it would be very unusual imho. I bought a used one that supposedly had 400,000 kms on it, and it purrs like a kitten. (I suppose if he told me it had 400k, it likely had 500k...lol).The kicker to all this is that the injection pump that I purchased was used. The seller assured me that the pump was good and only had approx 150000kms. Can the pump be defective and overfuel the system.
Having a leaking injector looks like overfueling. You will usually get a grey/black haze out of the exhaust at idle and it can get worse with rpm/load. Instead of injecting only when it's supposed to, it will dribble before and after the main intended injection. Dribbly fuel doesn't burn proper and results in smoke. Also, this can end in melted Pistons due to uncontrolled timing since there is always fuel available to ignite. It only takes a bit of crud to keep the plunger from seating properly so it's no surprise to me after a big fuel system overhaul this could happenHow can it overfuel at idle? Too much fuel would increase the idle speed.
What exactly are the symptoms. Overfueling is too much fuel for the available air yielding black smoke.
I wouldn't think that "new injectors" could be immune from sticking due to any crud that was sitting in a used IP. I don't think one can rule out the thought (yours) that there may be an injector or two that's stuck (due to crap).Ocnorb123 has new injectors after the pump was installed so this seems less likely tho.
There's always more to the story!I'd be interested in the story as well!
I'd check Group 013 and look for the odd one (or two) out and then swap around to see what happens.
.There's always more to the story!
We still need to know the beginning.
