Wanted to add to this thread because info within it was helpful. I have an 02 with 265K miles, original AC, never touched. Today while driving home in traffic within about a 10 minutes period over one hour into the drive, I could not get the AC to blow cool air after having been fine for at least a 30 minute cooling duration. Looking in this thread I saw the three green fuses above the battery mentioned. I found the one closest to the center of the engine compartment with a bad rear terminal. They are 30 amp fuses same dimension but different than your typical 30 amp full size blade fuse.
The fuse appeared not to have burned like you will find a typical bad 'blown fuse'. That rear blade only was dark in color and somewhat pitted. The plastic in the fuse holder around it appeared to have some mild melting around that blade only. I have never encountered a fuse that looks like this. I borrowed what I believe is the rear compartment power 30 amp fuse, put it in and out a few times and left it in. I always got the dash switch AC light on and it still worked. The large fan that comes on all the time the AC is on was not coming on, but now did and the ac clutch engaged which it had not before, and cooling is normal.
I was puzzled as there was no sign of Freon loss under the hood. I do believe I smelled the results of electrical arcing when this thing finally gave up.
Any idea why a single black corroded looking blade on a fuse like this? I cannot see what is down in the receiving end of the fuse assembly, but seems it cant be that bad given the AC works fine now. I will heat it up to high temps tomorrow. Could this just be the result of the end of service life for a blade fuse that has been highly loaded while in use for many years? How many amps typically passed through that fuse? Could it be the result of a metal impurity or flaw that finally came to fruition after 14 years and 265K miles?
