About the gibonata nozzles milan mirlu have on piston melted because the dlc om needle let off so nozzle keeps on fueling it. The engine en head damage no refunding ore compremis from gibonata.
I know of one case where the groove in dbilas cam was atwrong angle and caused valve to break off a bit later. So id say double check with dial indicator cam timing. Its a small effort
