Old November 3rd, 2017, 02:28   #16
Henrick
So the dealer refused to reflash the ECU?
Is there any other dealer around?
Ask them to flash the newest one (priot to dieselgate, which is supposed to be 9972) for a fee. Shouldn't charge more than 1 hour labour. Tell them you are having problems with EGR cooler.
Again, I'd suggest adding thermostat and fresh coolant to your TB kit.
Probably the source is referring to intake flaps. Not sure which 1.6 engines had them - mine does not but mine is not BlueMotion. You might want to pop the hood and check the intake manifold if there's a motor bolted onto side of manifold.
Doubt it was ASV. These are spring loaded and they have hall sensor which indicates the flap position. If it would be not fully opening (or not fully closing), you'd get a CEL and a code for that.
Henrick is offline   Reply With Quote
Old November 4th, 2017, 02:52   #17
z3011
TDI(s): passat
the dealer was not very interested at all to be honest.. as usual i guess..
as for the SW, i dont beleive it would change much for my mpg. but would be nice to get rid of some bugs anyway, yes
As rumor say, it is possible for everyone to get older SW if create an user at ERWIN, get one VAS5054, download ODIS it should be possible to flash for yourself. i dhave not study details, as this is rather new to me.. but i understand, this is probably smth who will not work for very long..?
the kit included thermostat too btw
my car is abluemotion. unfortunately i dont have the car here today, so no chance look at it now.. as for the flap. yes its just a theory.. yes it should make a cell of anything. just thought maybe it was very clogged with soot.. but from experience, even allot of soot, doesent change mpg allot it seems..
z3011 is offline   Reply With Quote
Old November 9th, 2017, 01:08   #18
z3011
TDI(s): passat
well.. not so much to update here. i only had this car for about a month, and in main, these are ok to drive and all i guess, but it feels rather cheap.. so probably will put it out for sale soon.
about the mpg "problem" i guess i just leave that to the new owner.. it is not terrible high, and for someone not very interestet in fuel economy, it should be ok. so guess wil leave to the new owner if upgrade sw or not too.
so most likely i will get one more B6 Passat with 1,9pd. very stabile engine in my opinion. give it new oil every 10000km, and it wil run "forever" also except maybe B8, the b6 is a very good loocking car i think
anyway thx for help and tips etc
Old November 29th, 2017, 06:06   #19
z3011
TDI(s): passat
In case anyone else has same problem, the solution here seems was timing.. after change timing belt kit, it dropped down to should be normal.
the old belt looked just fine too, but maybe was just stretched a little?
not sure, but i think these engine have no need for timing, except lock crank, pump and camshaft togheter? rest is set by engine ecu?
also there is sensor on cam and crank, so i dont understand why there was no faultcodes..? only the pump maybe could be off a litt, but i thought thoose 3 folow eachother, so.. strangest thing..
anyway it is a little more fun to sell smth who work 100%, so im glad i took that job, before put it for sale.
Old November 29th, 2017, 12:56   #20
Henrick
Doubt there exists a fault code for incorrect timing... At least PD engines allowed quite a big range for cam-to-crank timing. I have seen cars with Torsion value as low as -5.6 to as high as 4.0 or so... Such a wide range will vary between power and fuel economy a lot...
Did your crank, cam and fuel pump locking tools slide easily in when engine was set to TDC? Or was there a need to wiggle some component? If this was the case, then which component did not align properly before replacing the timing belt?
Also, what fuel economy does the car return after the TB service?
And one final question - was the water pump original one or was it replaced? The date marking should be somewhere on it... I guess if the dealer replaced the water pump (which is very prone to failure on this engine), there's a chance they screwed the timing.
Old June 1st, 2018, 07:23   #21
dspassat
TDI(s): passat
i have same engine (CAYC) Passat B7, and the best i can get on highway is 5.2L/100km. And that is when i reset the count in mid ride. There have been few times when the readings have turned normal (around 4L/100km) and that happend for 2-3 times in a one week period.
Car itself is working fine, have made thru two MOT checks with very good results, but the economy is very bad.
I have changed DPF filter, temperature sensors, fuel temp. sensor, lambda sensor, poured in all kinds of different additives, drove in summer and winter, tried summer tires and winter tires, and even timing belt kit got changed, but nothing made difference.
Only sensors and things that could affect fuel economy are camshaft and crankshaft sensors, but it doesnt really feel logical.
And ofcourse no fault codes.
Many say that you cant get the mileage what factory states, but i know that older 1.9TDI can make factory specifications, it just needs some gentle driving. If VW tells me that my car should have 3.8L/100km on highway (smaller VAG cars even 3.6), then over 5 liters is absurd. 20-30% more than factory specs, this is not ok.
There are many threads across the internet with same engine having bad milegage, hopefully someday we will have solution for this problem.
dspassat is offline   Reply With Quote
1.6L TDI Bluemotion: 70+ hwy mpg, available in EU r11 TDI Fuel Economy 4 June 2nd, 2015 05:03
TDI Bluemotion achieves 80 mpg booty TDI News/Tech 58 November 26th, 2013 11:23
VW Golf TDI BlueMotion gets 73.5 mpg trev0006 VW MKVI-A6 Golf family including Jetta SportWagen (~ 2010-2014) 12 June 27th, 2013 08:03
Passat Bluemotion good for 46 mpg US Ramsey TDI News/Tech 104 May 10th, 2007 15:21
Polo Bluemotion: 72.4 mpg Ernie Rogers TDI Fuel Economy 30 May 6th, 2007 03:50
Page generated in 0.13551 seconds with 11 queries
[Output: 76.70 Kb. compressed to 67.88 Kb. by saving 8.82 Kb. (11.50%)]
