Go Back   TDIClub Forums > Meetings/ GTG/ Regional Discussions > West Coast Canada/USA
West Coast Canada/USA Local discussions for those on the West Coast of Canada and the US.
Old September 27th, 2017, 22:58   #1
kiva822
kiva822's Avatar
Default need 02j tranny, code EGR
So, I'm on my 2nd tranny. First one went like 240k. used replacement went about 25k, it seems. Most strangely, is the used replacement is having the same symptoms the first one did - won't reliably go into 3rd when upshifting. Absolutely will not downshift without double-clutching.
anyway, assuming there is no other obvious problem I'm not aware of and this is just a weird coincidence, anybody got a known good 02j lying around, code EGR?
thanks
matt
Bola: 03 Wagon, RC2
Disclaimer: all advice worth price charged
kiva822 is offline   Reply With Quote
Old September 28th, 2017, 11:55   #2
Matt-98AHU
Matt-98AHU's Avatar
Fuel Economy: Depends on which TDI :)
I have one... Can I convince you to remove the short shifter with the next transmission you put in?
BTW, I eventually did tear your old trans down... 3-4 synchros were toast and the clips for the detents for the 3-4 selector were also broken... We may be able to simply fix your current trans by buying those clips and 3-4 synchros.
Sole Proprietor, Diesel Autowerks in San Anselmo, CA. One man operation, email is preferred method of contact: email me with inquiries for service.
Matt-98AHU is offline   Reply With Quote
Old September 28th, 2017, 12:27   #3
2many diesels
So Matt, are you saying the short shifter is an issue...if so im in trouble.
2many diesels is offline   Reply With Quote
Old September 28th, 2017, 13:17   #4
Matt-98AHU
Matt-98AHU's Avatar
Depends on the driver. You have to be a bit more patient with the super short throw setups (Like dieselgeek's sigma). You shift too fast, which becomes much easier to do with a super short throw, you're going to start damaging synchros...
If you're gentler and a bit more patient, you can feel when things are synching up and will be just fine. Not everyone is that attentive, however
I have had more than one customer with chewed up 3rd and sometimes 4th gear synchros who also happened to have DG shortshifters... Not saying the product is bad, it just makes it a little too easy to shift too quickly for those who aren't careful.
Old September 28th, 2017, 18:47   #5
dirtride
TDI(s): 2003 Golf
Fuel Economy: mid to upper 40's
This is great info, thanks Matt!!
Mark
03 GOLF ~ GLS ALH EGR (turned it into a mutt)
00 F-350 ~ 7.3 PSD 4WD ZF-6 XLT LBCC (modified, not a mutt)
dirtride is offline   Reply With Quote
Old September 28th, 2017, 22:02   #6
kiva822
kiva822's Avatar
Hey Matt!
This car doesn't have a short shifter, so that's not the cause. First tranny lasted 240k (100k by us). Next one 25k. Damn.
I'm all for buying those clips and synchros. Best time to call you to discuss?
matt
Bola: 03 Wagon, RC2
Old September 29th, 2017, 09:12   #7
Matt-98AHU
Matt-98AHU's Avatar
Originally Posted by kiva822 View Post
Hey Matt!
I'm all for buying those clips and synchros. Best time too call you to discuss?
matt
Dang, I thought it did... Must be thinking of someone else's...
Call whenever, leave a voicemail or text if I don't pick up. Will get back to ya when I'm not immediately under a car
Old September 29th, 2017, 17:22   #8
gmenounos
Any chance these contain some or all of the parts you're looking for?
https://photos.app.goo.gl/iLEDYQ8Z8cvSO5g92
They came out of my '99.5 TDI transmission (DQY I think) with 157k miles. It was becoming difficult to shift into 1st and 2nd but I never had a problem with 3, 4 or 5.
http://www.bitfab.com/tdi
gmenounos is offline   Reply With Quote
02J five speed, tranny code EUH. cstalnaker VW MKIV-A4 TDIs (VE and PD) 1 August 5th, 2013 18:47
WTB/ 02J EGR code Transaxle coolvdub Private TDI Items for Sale/Wanted 0 March 6th, 2012 20:08
02J (EGR code) transmission parts for sale gth Private TDI Items for Sale/Wanted 3 July 18th, 2011 16:17
WANTED: 02J 5spd Transmission - Code EGR skurbina Private TDI Items for Sale/Wanted 5 October 29th, 2010 15:40
VR6er needs help: Need Mk IV TDI 02J 5 speed tranny code or 5th gear P# MistralVR6 VW MKIV-A4 TDIs (VE and PD) 5 June 28th, 2002 03:57
Page generated in 0.13817 seconds with 11 queries
[Output: 89.07 Kb. compressed to 76.70 Kb. by saving 12.37 Kb. (13.89%)]
