First... head gasket number of holes is determined by piston protusion. Nothing to ask here. I had a 2 holes head gasket. It blew. I have to replace it but have been told to "repair" the cylinder head. That is: changing valve seats, and making a slight peel (i mean less than .25mm or maybe even only .10mm) of the cylinder head surface contacting the head gasket.
This being said i don't know if i should have a thicker head gasket installed in orden to counteract the small difference in head gasket height.
Shall the answer be: "NO keep with your 2 hole head gasket" then i've gotta ask... should i do anything to counteract higher compression due to smaller space between pistons and head? And if so... what?
Thanks a lot!
Thanks a lot!
