Dadwagon
Hello all,
Under braking, my 04 wagon shutters both the brake pedal and steering wheel. Just about at any speed over 20mph.
Obviously the faster i go, the worse the condition.
I bled all four corners and topped off the fluid- the front pads look about 80 percent good, rotors don’t feel very pitted or grooved either.
I did a front wheel tie rod check (lift vehicle, check for side to side play in wheel) Both front wheels felt solid, no play side to side or up and down.
I am wondering if it could be a bad master cylinder? There is a lot of travel in the pedal, and i don’t get a good firm feel either., (kinda squishy pedal)
I am thinking about changing the front rotors and pads simply to rule them out, wondering if you guys have any suggestions here.
Thanks,
Dave
Thanks,
Dave
