AndyBees
- Joined
- May 27, 2003
- Location
- Southeast Kentucky
- TDI
- Silver 2003 Jetta TDI, Silver 2000 Jetta TDI (sold), '84 Vanagon with '02 ALH engine
As the title says, the OPEN DOOR SYMBOL (red) is ON in the cluster.
This is the 2002 ALH works in my Vanagon.
That light has never been ON previously. There is no DTC for it or anything remotely related.
I've searched my electrical schematics, note book, etc., and not found anything that I did to eliminate this symbol. I do not recall doing anything either (pre-August 2012).
Most recently, I've had the Cluster out to re-do ground wires, tidy up wiring in the dash, and re-solder the connections (each end) for the cruise control. Engine starts and runs fine....... one DTC #3 GP and the flashing GP due to a bad brake switch (on order).
Anyway, if anyone has some insight on this issue, thoughts, suggestions, etc., they will be deeply appreciated.
In the meantime, I'll keep searching the schematics for a solution.
