Strut Rubber Bushings in Engine Compartment
Dieselista
Virginia
06 Jetta, 03 Bug, 74 TR6, 92 Ducati 907ie, 96 F250 PowerStroke
Does this look normal? I've owned this car for a while and can't believe I never noticed this, there's no dust line around where the bushings would engage the body, but they sure do look like they have a slot for engagement.
Mongler98
COLORADO (SE of Denver)
yes. totaly normal depending on the suspension parts. some have almost flush, some have as much as yours. i for one with brand new parts bilstien and upper HD bearing rubbers and what not had as much as you do.
KLXD
Lompoc, CA
'98, '2 Jettas
The struts just sit in the cups in the body. Or rather the body just sits on the bushings at the top of the struts.
If you jack up the car you will reach a point where it lifts away from the bushing and the top of the strut will move around. Keep raising the body and that gap will close up and the top flange will hit the body and start lifting the wheel.
South of Boston
Totally normal. A gap of 3/8" or so is fine, much more than that and you need new strut mounts.
JETaah
Vendor , w/Business number
mi 48836
There will be a gap of varying amounts depending on the equipment. If the retaining top dish (and the strut shaft) is far off-center that would indicate that the rubber bushing is collapsing.
